I have a 1996 Zetor 4340 with about 2500 hours on it. When I try and lift the 3 point hitch up to its maximum height (DM) it is all I can do to move the inner circuit lever into position. It seems to move easily until the last 1/3 of travel and then I must use two hands to move it the last bit. The hitch doesn't start to move until this last 1/3 of lever motion and it seems to have about a 5 second delay.
The preselect control lever is in P or fixed position and the outer circuit is in neutral.
The reaction control lever is set for maximum oil supply.
It seems to be difficult to move with or without an implement attached to the 3 point hitch.
Any suggestions on what I should look at to make this easier to operate?
