How much does a 5211 weigh?
M
mitch
Guest
Hello all,
We've got a couple 5211s, one with a bucket, one without. Could someone give me a rough estimate of how much these things weigh?
Thanx a million.
-Mitch in MI
I guess it's weight at around 3000kg (6,600 lbs).
There should be a plate on the tractor giving its weight.
TomZ
Tom
our 5245 with standard front ballast (under the front part of the nose) weighs 3180 kg.
A 5211 will weigh 2600 to 2900, depending on tire size, used ballast and if a cab is mounted or not.
Sorry, a cabbed and ballasted 5245 will weigh between 3080 and 3100 kg. That's what i meant.. ;)
It weights 3180kg.
This one is really good site, http://www.konedata.net/Traktorit/zetor .htm
One finish man has colleted tecnical data of tractors (and combines) imported in finland 1960-1995
Hi Hogi,
This site is great! There is lots of technical data on Zetor (and other tractors) in there.
If you know the person who put that site together, you should put him in contact with Renze.
TomZ
Tom
yes, that guy collected more detailed data than i did.... :)
