N
Norwegian Zetorman
Guest
The thing is when i drive something heavy and up the hills it is just getting a whiteblue smoke out vof the exhaust shoulnt it bee a little bit black to get Max horsepower.... It thought maybe i could adjust the Fuel pump a give it a little bit more Diesel. It is not the most easy started tractor either but that can also cause of other things i shall also chech the timimg of the pump and adjust the valveclearence and check the Injektors.. It has runned 2600 times so it is much tractor again... But is there any who have had the same problem and have some advices. it is Spesially how to give it a little bit more Diesel i wanna now, ihave also adjusted it too top rpm 2400 instead of 2200. it is also a other type pump at 5011 than the newer 5211.
_______________________________________________________
Ich been eine Norwegen
