So I just purchased a used 3320 with allied loader, going through a complete fluid change.
As for the hydraulic / trans fluid, I've read many cases that 80w-90 should be used and others where TDH is used. It was recommended that I use 80W-90 but my fear is that as I will be using the tractor for plowing in the winter and the hydraulics would run too slow (-25 c).
Also any diagrams as to the location of the drain plugs? I was told that the large plug underneath the rear 3 pt hitch will drain most of the hydraulic oil.
