- Feb 18, 2005
- 36
- Andy Jordan
Does anyone know how the hydraulic safety valve works? I am having a problem with my 3pt hitch - it will lift fine, but will not remain in the raised position - it immediately drops until the mounted implement (skidding winch) is on the ground. The selector is in the P position, and everything else seems OK - flow rate can be adjusted without problems etc.
It is pretty cold right now and I am thinking that the safety valve might be kicking in because the oil is too cold, and therefore too thick. I only used the tractor to clear snow yesterday, so it was only running for 20 minutes or so, but I didn't notice any improvement - I had to hold the 3pt hitch in the raised position.
Does anyone know if these symptoms are likely caused by the safety valce, or is there likely to be another problem??
Thanks,
Andy
Thanks,
Andy
