F
flax
Guest
The hydraulics are slow on my 6245 , I have a loader on it and to use it effectively have always had to run the PTO at 1000 when working the loader.
I finally thinking of replacing the hyd pump as it's slowed up even more recently but , I am not convinced that it will fix the problem , Reason is my 6245 has only done 2000 hours , I had the loader put on about 12 months ago , so the hyd pump has never had to do that much work ( maybe 200 hours at 1000) and I find it hard to beleive it would be stuffed after such a short time . ( Hdraulics was always slow when I bought the 6245 second hand at the 2000 hours and before the loader was added) .
I changed the oil , filters etc etc and it makes no difference.
Any suggestions?do you think I should get the new pump
By the way are the Vapormatic pumps any good , they are much cheaper than the orginal zetor ones ( in australia anyway )
