Injector oil
N
noursead
Guest
Hello all,I need to know how much oil the injector/govenor holds in ounces? I don't seem to have a check plug on it?It is on a 5211 with the 5201 engine.Thanks to all.
X211/X245 models have automatic lubrication of the injector pump from the engine don't they? I Thought Zetor said so in their leaflets at the time.
On the side of my injector houseing there is a lable that recomends an oil change evey 200 hours.It does not give the quantity?
Is there not a bung that you remove with a mark (horizontal line besde it) that you remove. You fill oil from the top through another bung until it comes out the lower one. That is the way it is on the Crystals anyway.
TomZ
Tom
Hi all,
This post makes me wonder if there is a requirement to add injector oil in the 7745. I had a good look at mine after seeing this post but cannot seem to see a filler plug.
Anyone know the details here?
Paddy
No mention of adding injector oil in the 7745 workshop, parts or owners manual . I too would be very interested in knowing what this is all about.
The 7745 injector pump is fed oil from the engine so it does not require topping up.
