Just bought a 6341.... Some questions?
Ok Renze. Old zetor 7045 parked 6 months ago.
I have done work to the hydraulic system. Changed pump, distributor, safety valve, overload valve etc.
Work done, filled up With 28 liters of oil.
Then I start the tractor and try to take off, but it wont move at all.
So Im thinking either the clutch is somhowe stuck.. Or?
Could it be someting else? Stuck in neutral....? Clutch suddenly bad?
Hi low lever in neutral. if clutch was stuck you wouldent been able to get it in gir or stop if it was in gear. Because its not possible to be stuck clutch in off position if it worked when parked. take off the inspection hatc on the side of bellhousing and look inside to see whats going on.
I took off the inspection hatch, but couldnt see anything obvius was wrong. But I dont really know what to look for either.
Shot a video of what happens when I try to drive.
https://www.youtube.com/watch?v=9OzFWEMz4ew
I got it barely moving, but its like the clutch just barely engages.
And I know the clutch worked fine when I drove it to the shop last year.
Any ideas?
A piece of metal blocked the pedal so it wouldt release all the way. Removed it and clutch seems fine now.
On to the next problems... :)
Just a heads up on the 6341 plastic parts. They are easy to"weld" With acetone. It melts the plastic.
And they are expensive to buy New, Ive fixed and repaired missing parts and all cracks.
