loader plumbing
dyates
dyates
I have a 5211 with westendorf loader. It is currently plumbed through the rear auxilliaries. I understand I can get pressure from the outlet on the pump plate under the rear axle and put a return line into the plug hole in the bottom of the transmission. Is this the extent of the plumbing, or is there more. Do I have to block flow somewhere else? I'm just trying to figure out how to use the loader at the same time as implements while also getting better function of the loader. If it makes any difference, I plan on taking the loader off of this tractor and putting it on a 3340.
