Hello.
More information required,.......
did the engine seize? (too hot, or big bang?)
or is it jammed in 2 gears and you cannot find neutral (this is a common problem on Zetors, and an easy fix)
to test.... put it in neutral and let out the clutch, if the tractor drives off then a selector shaft has slipped into gear all by itself, any attempt to find another gear will lock the box solid as you will be in 2 gears at once.
The factory shop manual is a tough read! and offers no tips for problems such as above.
====edit by webmaster:
WARNING: advertisements on the bottom of your post, for cheap DVD's are concidered SPAM. Even if you DO make useful contributions to this site, spamming is a serious annoyance to everyone, which will get you banned !!
Ok thanks for pointing that out: I thought somehow a user account was hacked, which lead to one genuine post under the name of the spammer, with an added spam message.
Now i know its cut n paste i can block the account, without letting the good suffer with the bad...
