losing oil between pump and distibutor 6245
forterra9641
forterra11441
the 6245 cant lift almost nothing and it barely has pressure on the outtakes to so im suspecting the pipe between the top ans bottom is cracked. the pump is new and the oil is at normal level. has anyone changed this pipe? do you need special tools etc ?
Email Dale Strong. He just did this procedure on his zetor .
I belive he had to get the tool from zetor to flange the pipe in the tractor body.
//Tom
you didnt just blew an O ring between bottom, or 3pt hitch cover, and the main body ?
To pull the high/low range layshaft out of my 3011 i made the tools myself because nobody could provide them.
Oh, and depending on where your pipe burst, would it be able to joint a new piece inbetween, with standard compression fitting ?
i think the pipe has rubbed against crown wheel.... this has happened on rear occasions. or it might be the main distributour. its no way to know before i take it apart. its my riends tractor and he dont have the time right now so im doing some research in the mean time.
