Moving really heavy stuff on the lift...
Hi Renze!
I think the answer to your question is back up there in the first post on this thread :D
O.K. ;) And Alzet and Tom have already given an answer to that as well... :D
Are there no contractors in your area, that have some big flatbed trailers and a loader tractor, or wheel loader to load the bales ??
...Only if you could find someone renting out some wagons and a wheel loader, you could pull the wagons with your 6945 and leave the bale handling to the custom worker....
Hey, and guess what?? Markku was exactly right.
If I move my hitch position lever slightly forward from the fully back position (marked NOSTO on my tractor too), the hydraulic pump stops groaning!!
Thanks Markku!
So, the pickup trailer hitch is blocking the lift from going fully up, so the pump keeps pumping pressure under it because it doesn't reach the height where the control system locks the lift cylinder and returns the pump oil flow pressure less ??
No, It's something different. There is a setting for the position lever beyond the "fully raised" position.
If you do as Markku described, and put the sensitivity lever to the right, then the arms move up slowly. Very slowly. BUT if the position lever is moved into the rearmost position they come up just as fast as if the sensitivity lever was full to the left. In _this_ position, the pump is running the whole time - when there is a heavy weight on the lift, anyway.
It may be that your tractor is different; Markku implied that this arrangement was because of the Finnish trailer coupling system. I can't comment on that because I don't have any experience of tractors that are for other markets than Finland.
Cheers for now
J-P
Nice You got the idea!
Unfortunately Renze is in right too. The finnish type trailer coupler can sometimes limit the moving scale of lower arms ???
If you adjust the coupler lifting rods longer the coupler doesnt get up enought.... And if you srew them tight the hitch cant get totally up.
But this type of coupler is very handy and we can pull huge loads even from difficult places. And finnish law says: You can not mount any connection that is higher what wheel center is :(
I am a criminal!!!!!! My round bales is connected to trailer coupler :p If police does read this Ill be in jail soon!
