need 6945 grille
arthur
Arthur
I recently bought an older style 6945 and I plan to fix it up. Its cosmetically rough. Im looking for a grille for it but cant seem to find one anywhere. Part number is 6911 5303. Unless it changed up to a new part number. Anyone know where I might be able to get one. Im in Canada.
Im also looking for a gauge cluster or instrument cluster for the dash. All mine are broken, and Id like to keep it looking original, and most aftermarket gauges look way different.
Its a newer 10 or 12 series grille upside down. And maybe the opening size is different.
Hmm the 9 series are rare here so i had to check: the 6911 has allmost the same grille as the later series, yet it was still mounted the old way. Newer ones had no steel wire mesh but a plastic mesh.
any other grille panel of a 70, 72 or 73 should fit, just that you wont need the attachment clips for plastic mesh, but you need to attach the steel wire mesh to it in some way.
its the plastic grille without the headlights and it mounts with the little twist clips in the middle, not at the top like the newer ones.
