Hello.
hi I have just purchased a 7011 2 days later the back arms dropped and that it where the stayed I have Checkedthe oil level and that is fine what else could it be if it is the pump what sort of cost is a new pump
in what position is your PTO selector lever ? if 540/1000 is in neutral, the pump isnt running either.
With the small lever next to the gear range lever, you can choose to drive nothing, only the oil pump, PTO and oil pump, and ground speed PTO. if this one is in one of the 2 upper positions the pump isnt driven either
Thanks for help I have stripped the pump of the tractor already so will clean all parts and re build and then check leavers.
Would anybody know where to order new gasket as the old one is in poor condition.
