plumbing a loader to 7745
pathayes
pat
Hi all.
I am trying to fit a loader to my 7745 she is the old white roof type. The thing is I am trying to get it to work independent of the power pipes at the back. I know there is a way to plumb the spool valve direct from the pump but I can't remember how.
Any ideas?
A plug under the rear axle housing, in the pump mounting plate. However it would also require to plumb the return from the loader valve into the port that normally feeds the 3pt and external remote valves... Which means getting through the 3pt cover. Plugging it into the rear remotes worked fine for me.
