Power Steering Leak
cook37184
Cook37184
My 4340 is leaking fluid at both tie-rod cylinders. Can one replace these seals? Or should I take it to some sort of specialist?
Thanks,
Greg
You are going to have to bring it to you local hydraulic cylinder repair shop anyway to get the new seals.
I loosen the end cap (normally screw on) and the slacken off the big nut that holds it all together. The seals, spacers and packers can then be easily removed and handed in to get new ones of the correct size.
