priming hand pump 6211
Ireland jdh
john
Hi there again.
I have a new problem I would appreciate A bit of help on,i recently had problem with lack of diesel coming through, the glass bowl was only half full and lot of bubbles, I drained the tank and found that there were a few sticks lying on bottom of tank, I took the tank off and had to take the pipe unit of too as i could not get the sticks out any other way, I have tank nice and clean now, put everything back , i put a small fuel filter on the main pipe plus a non return valve, i also changed the main diesel filters, but now she still needs to be primed, how would diesel be getting back to tank now,
Many thanks for any help.
There's probably a perished pipe on the leak off/return pipework. Clamp the return pipe and presurise the system with the hand primer, it should show up any leaks.
thanks mike, sorry but i am not sure what pipe you mean, is that the return pipe that is connected to the back of the injector pump
