PTO and BRAKE CYLINDERS
willie
Phillip
I bought a 6321 2wd with cab and loader approx 5 yrs old. My problems are the PTO will not work as soon as it comes under load. And both rear brake cylinders are leaking bad. How do I fix both. Thanks
Don't know about the PTO. for the brakes, take bottom out of cab and you will have easy access to the brake cylinders. You don't have to take the rear wheels off like Zetor told me. Make sure you get the new brand of cylinders-frankov, or something like that.
If you have drum brakes, you do need to take the rear axle portals off to get at the slave cylinders.. They are inside the drum, which has to come off the halfshaft before you can reach them.
I think you're either talking about the master cylinders, or about the slave cylinders of disk brake systems. (in either case i cant see why you would want to remove the cab floor)
A 5 year old 6341 has disk brakes... dont know if its the dry disk with cylinders accessible from the back of the tractor, or the wet disks found on current series. I dont know where the slave cylinders are located on the wet disks.
