- Joined
- Oct 4, 2004
- Messages
- 9
- First name
- Nick Karantinos
Greetings All, Getting to know my 4340 and sorting out problems from tractor being idle for at least two years. So far I have repaired the foot brakes, changed oils, replaced trans oil and repaired the starter circuit, etc. When I finally hooked up a 10 Ft. finishing mower I was pleased with the results. The problem is that the PTO disengages in use after a few minutes. To engage the PTO, I lifted he PTO hand clutch but it still grinds. Eureka! I have found it!!!!! The PTO hand clutch is disconnected!!??? One picture in the operators manual shows the PTO Lever being on the left closest to the seat. After adjusting the free play on that lever I found it was the hand brake! The outer lever (the one nearest the left fender) was the PTO lever and was disconnected. Now, my question is has the PTO system been damaged or will it sort itself out with a new lever and cable installed and properly adjusted, that is, does lifting the PTO lever to engage the PTO somehow lock in the PTO? Thanks, Nick
