PTO Shaft Update
falmathoros
Nick Karantinos
Hello All, Has anyone replaced the PTO shaft and shifter mechanism (4340) with the updated parts which presumably will correct the PTO selector lever from jumping out? This jumping out is caused by the outer circlip on the PTO shaft jumping out of its groove allowing the bearing to slide rearward on the shaft. A simple fix is to replace the circlip, however, if the brilliant former operator continued to jamb the PTO lever "in", the front splines of the PTO shaft and the corresponding shifter splines get damaged. Thanks, Nick
P. S. This is a new post not intended to be added as a reply to Smelly.
