- Joined
- Oct 4, 2004
- Messages
- 9
- First name
- Nick Karantinos
Greetings, Has anyone experienced the "popping out" of the PTO selector lever to neutral? In a 4340? The manual suggests replacement of the detent spring with one of more tension, but concludes this may not work. The second "fix" is to reset or replace the snap ring on the PTO output shaft. Finally, the permanent "fix" would be to replace some PTO components to newer versions. Has anyone done this and what is the degree of difficulty? Thanks, Nick
