question Radio install Zetor 7745
CRYSTAL8011
Ireland
Ronani
Zetor 8011
I would like a radio in my 7745, I see some radios mounted above heater and wiper control switch.
What is best way to wire a radio here, can I wire into existing wires or do I run new wires ?
I think the red wire is for + and the grey one for -
So you should be able to wire a radio with. (y)
No, its not needed.
But I would put a flying fuse in between and possibly think about a battery isolator switch so that the tractor can be easily disconnected from the battery when it is not in use for a long time and to protect it from deep discharge.
In this case, a radio is useful, which saves its settings/stations even if the voltage is completely lost and does not require a security code to be entered. ;)
