removing bell housings
luke4911
luke4911
I have a zetor 4911 with a cab that I am planning to do the brakes on. Does any one know which ring of bolts on the "portal" I remove? And do I need to remove the oil
Thanks on advance
you need to drain it below the heart of the differential. and take off the row of bolts on the diff housing, the brakes are inside of it. Use an engine hoist to lift them from under the mudguards, they are heavy and impossible to manoever by hand.
