- Jul 5, 2003
- 4,071
- Location
- Laag Zuthem
- Renze
- Machinery:
- 1976 5718
1967 3011
Hey guys,
I bought a band saw, a machine that costs 1200 Euro new. I bought it for 150 euro, and replaced the missing coolant pump by a 70 W fish pond fountain pump.
Now there's a problem:
The saw is a 400 volt 3 phase machine, and the little coolant pump is a 230 V single phase.
I know that a 4 pole wall plug has 3 phases and a ground, and that a 5 pole wall plug has 3 phases, a ground and a null.
The 230 Volt connection is 1 phase and a null.
Now here comes the question:
Is it safe to get a phase from the 400 Volt main switch (to switch the coolant pump simultaneously with the saw motor) and use an extra 230 volt connection with only 1 wire hooked up, to get the null to split the phase into 230 volt (like any normal 230 volt connection does)
The 230 volt pig nosed wall plug can be mirrored. Would i risk hooking up 2 phases to the coolant pump motor when i turn the 230 v plug upside down ?
Or would i be better off installing a dedicated 5 poled wall plug for the saw ???
How do i determin what the null is in a wire joint box, i do have a voltage meter but how do i measure it ? My brothers and uncles have been messing with the wires for 20 years in my workshop, so i dont think the connections are hooked up according to standardised wire colour codes...
