Too run,or not to run ?
timber
timber
:cool: First of all { cool, & very interesting } web site
I have a Question ?
My problem is that my 7045 4wd shuts down on it's own. I
replaced the fuel tank, and put a clear see through fuel filter in
supply line. I went as far to installed a electric fuel pump to help .
I cleaned primer blub out after finding pcs of inner fuel tank liner
pluging orfis The ZETOR ran for appox a hour afterwhich
stopping, and refused to restart. I started the ZETOR yesterday
w/ no problems and ran it for fifteen min. at varies rpms w/ no
problems, but The Zetor is starving for fuel and I'm not sure
why? what are your thoughts ????
Change the fuel feed pump under the injection pump. I had teh same problem caused by just one little fiber ring.
What's involved in changing a fuel pump ?
and where would I buy a fuel pump ?[flash=http://www.website.com/flashfile,width,height]
Timber
I think you could try to blow the fuel lines clean with an air compressor first. I think a line is plugged.
Sometimes you can get a vacuum in the fuel tank if the breather is blocked.
Test by removing the filler cap just after it stops - do you hear air rush in?
The pump is more likely the problem as above.
The problem turned out to be a crack in the rubber supply fuel line. the crack allowed the fuel pump to suck air in. :):)
imagefile,optional_width,optional_height,optional_alttext
