Mike,
I remember that they had a kit for 12 series. It was presented and available too i think. The problem was that my father didnt "need" it and when i tried to buy one later dealer couldnt deliver it.
The problem with super series kit is that you need constand oil flow for it. In earlier ur1 models you need to fit it on original external valve. And when you have brake valve connected, you can not use any other hydraulics
Also you need "steal" preussure from brake circuit to valve pilot, least when you use "standard" brake valves. I have fitted Valtra brake valves to build hydr. trailer brakes to my
zetor /ZTS. Zts has possibility install valve to its
hydraulic circuit. Also my 7745 has more external valves (my own assembly), so it is possible to fit brake valve to that circuit.
But finding original kit for aftermounting UR1 series would be nice. It didnt need taking pilot preussure from brake circuit if i remember correct, so maybe it used the same system as air brakes.
BUT this is only what I REMEMBER. I dont have all hairs anymore, so it is possible i dont have all memories as correct anymore either
