turbo kit for 3 cylinder zetor
per_ola
Per Olav
Hello
Is the turbo kit for 3 cylinder zetor (5211/45-3320/40) still available??
I want to take out more power on my 5211.
Here in Norway there was sold a few 6545 in beginning of the 90`s Turbo was also option for the 3320 and 3340. Someone out there who heard about turbo on these models????
you could probably get a turbo from a golf 1.8 tdi and convert it too fit.it may be half the displacement but runs a twice the revs so should work:D
5213 and 5243 orchard models had a factory turbo version, i dont know which turbo.
1.9TDI turbo will work but maybe a bit big: However these modern things spool up fast enough. A turbo of an old 80's 1.5 TD might work because the air flow is quite the same (it made a 50hp standard into a 70hp TD, the same as you want to accomplish with the Zetor ) but because of the older generation of turbo, the bigger 1.9TDI turbo might spool just as fast. turbos of a 1.9TDI are a lot better available on scrapyards than those of the 1.5 though..
Biltema sells cheap turbos and by pass valves etch accessories. Maybe you could built your own solution from those goods. Aftermounting kit pays about 2000 euros least and Biltema parts are 400 to 600 euros maybe ;)
