Hello.
Hi all HOPE YOU ALL HAD A GREAT CHRISTMAS
Does anyone know if you can fit 12.4 / 24 stomold tyres on to a 7245 , as a replacement to the 11.2 / 24 that are on there now .
it does have a loader on if that makes any difference, any help would be great .
thanks martin
Hi renze
I have 16.9 r 30 on the rear do you think they will match with the 12.4 / 24 `s ? , just needed to check that they didn`t get too close to the assister ram either but if you have them as standard they must be ok .
rolling circumference must match, or the tractor will eat rubber when in 4wd on pavement... As said, diagonals often are higher than radials because the carcass is stiff.
