UR1 series centrifugal oil cleaner
dandd
Dandd
Hi please can some one help
The centrifugal oil cleaner on my 6718, is the internal removable cylinder that splits in two, is this meant to have a o ring or seal between its mating faces
And secondly the removable top of the oil filter housing, where the dome top sits on the housing is that meant to be sitting on a seal also?
I cant find any info on it at all.
Cheers
There are two rubber o-rings inn the partslist: partnr 931230(95x3MM) and pnr 931244(124,2x3MM). I asume the smaller one is for the sentrifuge and the larger one is for the dome.
Bjarne
Thanks for that
Thats great. The larger dome one is not available anywhere as far as I can see so that will be silicone gasket maker
Bjarne
Can you put a picture up of the explodid diagram of the oil cleaner housing etc by any chance please?
If you og to:https://www.maskinisten.net/ you can download the partsbook and shop manuals after you creat an free acount.
Bjarne
