question Ursus C3310DT - Problem pto splitter facing uphill
Pixucs
Romania
Marian
Ursus 3110 DT
Please help .I heave Ursus c3310dt and i heave problem with pto and torque when going uphill.Oil level is ok +5 cm over dipstick mark, filers ok, oil clean.When going downhill everything is normal, all work-s fine.what should i do?Thank's
Hello Marian.
I think there isn't enough oil in there, so the pump draws air and the hydraulics no longer work.
Would it be possible to add a little more oil to the gearbox than you already have?
The oil when going up hill would move toward the back of the tractor. How steep the is the hill when you loose oil to the pump ?
At the bottom of this chart it notes adding more oil when working on a slope.
