water mix oil
zeopepe
machpepe
Hello everyone,
Please, can somebody discower the following problem.
I really respect it.
When coolant mix to lub oil sump, what is the most
probable reason in our hand?
Cyl head casget, O-rings at cyl liners bottom or what else?
Tractor is 8011 year 1973
I ve never seen cavitation on Zetor liners. However there is only one way to find out:
Start at the heads and check the head gaskets. If that shows no suspicion, continue with the liners to check the O-rings.
Allways replace liner O rings with plenty of grease, and wire brush the mating surfaces.
i once started stripping down a crystal 8011 with water on the pistons, when i got the manifolds off , there was no antifreeze in the water.... it had been raining heavily though.:(
