water pump torque specs
The shopmanual dont spesifie torque for these bolts, M10 bolts are inn general torqued to 29-47NM and the engineblok is made of cast irone so one shold not need to use max torque.
Bjarne
Thank you very much for the info and the time to reply. Sounds reasonable to me since they were very easy to remove. The bolt markings are 8.8 SL. Also i'm thinking of using a little gasket sealer although it seems none was used from the factory. Just waiting for pump and parts to arrive. Thanks a million for supplying the info fom your manual .
