were the zetor 4611 and the 6711 rare in ireland ???
greendragon3
greendragon3
hi all zetor kings , just wondering if the models 4611 and also the 6711 were a rare model back in the day ??
apart from the 3513 and 3516 and 3517 what other scarce sought after models were available in the zetor range ??
4611 is 4511 with cab. Same as the wide 5718 cab but then with sheetmetal untill the height of the doorhandle, instead of glass.
6711 is a cabless 6718 and not rare here in Holland.
Dont know about Ireland but the 3016 and 3017 are the most rare models in Holland.
This link http://www.boards.ie/vbulletin/showthread.php?t=2056956089/4
shows the restoration of a 25, 35 and a 4611.
The 4611 is a four cylinder with 53 hp.
I would not like to be looking for parts for these at least here in Ireland.
6711 was pretty common in england during the seventies
have to say id never heard of a 4611 until this week
in england it was 11 series without a factory cab, lots had duncan cabs fitted
18 series had the zetor cab
45 series was 4wd
35, 45 hp were 3 cylinder 55 and 65 hp were 4 cylinder
seemed to be more 3045 than the 2wd versions, i dont recall ever seing a 45 hp 4wd but the 55 and 65 hp were common in both 2 and 4wd
exception to the rules wwas the 4712, apparently some clothing company had a pair of 4711 jeans and trademarked the number so zetor couldnt use it..
in the same way crystals were 8011 and 8045, untill 6 cylinders and turbos appeared
4711 is a French Eau de Cologne.
