What oil for Zetor 6245 transmission?
lspringeradelphianet
Popeye
HI
What do most owners use for oil in the transmission / hydraulic system?
I'm about to change my oil.
I've been using Universal Tractor Hydraulic/Transmission oil, but I notice my manual ( 6245 ) says to use 80/90 weight gear oil??
If you search this site you will find several, long, discussions on this exact subject!
To cut a long story short .......
Both will work just fine
if the hydraulics are getting a bit tired then opt for the slightly thicker (but only slightly) 80W90 Gear oil (actually much the same viscosity as SAE30 motor oil, but with different additive package)
However if you live in a country where you have to dig the tractor out of the snow to find it 3 months of the year, opt for the thinner UTO
UTO's have 'all the additives' for both Hydraulics and for gear operation and are therefore more expensive than standard gear oil, (and much more expensive than simple hydraulic oil). but foaming is less of a problem with UTO than with Gear oil.
DO NOT use Standard Hydraulic oil in a gear box, it will cause premature death due to not having the all important 'extreme pressure' and 'Film Cling' additives required in a gear box and Diff.
thanks steve
by the way, i can't get the search function on zetorworld to work
maybe i'll try 1/2 UTO and 1/2 80W90
thanks steve
Might be related to the problem i had last week or 2, that nothing was working other than the homepage...... just came up with page not found errors.
Renze will get on to it
Just tested the search and it is working as normal from me (once you click on "open this content in a new window"
This content cannot be displayed in a frame
To help protect the security of information you enter into this website, the publisher of this content does not allow it to be displayed in a frame.
What you can try:
Open this content in a new window
Did a search: "What oil" and the following thread came up that you may find useful.... but is just one of many on the subject!
