which loader fits on a Zetor 4718
steffens
Steffen
Hello
I own a Zetor 4718, I would like to mount a loader on it.
but what model should I look for?
And is a good idea and putting loader on this model?
many greetings steffen
3 cylinder aernt they? so a 3511 loader 3545 will all fit, job to find one though! ok to put a loader on it depending what you are going to do with it?
matt
thanks for the reply, yes it is a 3 cylinder.
I do not quite understand what you mean by "sow a 3511 download 3545 goodwill all fit"
sorry
is it from a different model tractor?
I just want to use to remove snow, and other small tasks.
mvh steffen
most of the loaders made in the last 30 years are made with bolt on subframes or mounting brackets to fit a vast range of tractors.... so for example to fit a loader from off a ford to a massey you only need to change the mounting brackets.
finding a loader should be easy... finding the brackets to fit it to your zetor may be difficult.... however with an angle grinder, welder , drill and some steel anything is possible...ive got a massey ferguson loader on my zetor 8011.
it was good to hear that there is hope for the success of finding a suitable loader.
I am aware that it might be necessary that I should adjust the brackets to be used on my traktor
my question is now what loader would be the best fit for my tractor?
perhaps a certain brand?
and where on the tractor is should I mount the bracket?
how do I make the hydralicken the best way, I think of where I need to take the oil from and so on?
I myself am a plumber so the pipe work is no problem.
steffen.
