Which Oil to use where?
patrick1481
Patrick1481
I want to change all oils on my Zetor 6711.
Now I need to know which oil I need for what and how much of that?
Anybody an Idea?
80w/90 in the end reduction and main gearbox.
10w/30 multifarm in the main gearbox and engine
15w/40 in the engine
as you can see it doesnt get that precise. just 15w/40 is motor oil only and will absorb water in a cold gearcase, and 80w/90 cant stand hot engine temperatures. 10w/30 universal oil does both.
So don't use 10w/30 in end reduction. It doesn't lubricate in hot conditions
Yes they dont prescribe 10w/30 in heavy loaded gearcases, only in engine and rear end sump (transmission and hyraulics)
I dont know why actually. 10w/30 and 80w/90 are about the same viscosity, only 80w/90 is a gear oil, so the viscosity is measured at an oil temperature as is common in a gear case. 10w/30 is a multi oil, so the viscosity is measured at a normal crankcase temperature, about 100C
when 80w/90 gear oil, and 10w/30 are both at the same temperature, both will have the same viscosity.
As Hogi says, 10w/30 doesnt lubricate in hot conditions, 10w/30 can stand more heat than 80w/90 but lubricating meshing gears, is something totally different than lubricating piston rings, or slide bearings (hydrodynamic lubrication)
Am i right Hogi ???
oil seems easy but it gets quite complicated sometimes.
Visit www.farmersbase.com and click at Kroon Oil at the right side. Then you can look for your tractor and find the right kind of oil. Regards, Peter.
I didn't read the above messages....sorry...the Zetor-people are the REAL SPECIALISTS ! 69)
