Workshop Manual for 3545
kjhanscom
Kevin
I had a problem with my brakes on my 5245 a year ago. I replaced both master cylinders and it helped some. My right brake didn't work at all and would inject air into the system. My left brake would work ok until this year. Now I have nothing and both pedals go to the floor. I can stick my finger into the brake drums and they are all wet. I assume both slave cylinders in the brake drums are shot.
This fix is a major undertaking having to remove both gear portals / axles. While I am in there I will have to replace the brake shoes since they have been soaked in brake fluid. I am curious where I can get the best quality slave cylinders so that I don't have to do this again a few years from now.???
I dont think there is much difference in quality for the slave cylinders. On the 2 series, the master cylinders from PAL wer major troublecausers. With a Fragokov replacement, it's all over.
The slave cylinders never gave much trouble. I think as long as you use originals, nothing will go wrong.
Does anybody know how much of a job it is to remove the axles and get to the brake drums?
I have the same brake problem and have been using the hand brake exclusively. It looks like a MAJOR job! My rear tires are liquid- filled and very heavy. Just getting them off requires special equipment. Those slave cylinders are very difficult to get to so I have been putting off the job....
My brother changed the slave cylinders on a 1972 4712 two weeks ago... that was the first major repair in 31 years !!
Anyway, i will ask him about this. I thought it can be done in one or two days.
I don't have the liquid filled tire problem, but it still looks like a major job. I am just wondering how to handle the heavy axles once the are un-bolted. Plus the fact that after it is replaced - I don't want to do it again for a long long time. My tractor is a 1989 with about 950 hours. Seems like it should last longer.
The slave brake cylinders never cause trouble till age 30....
What brake oil do you use ??
Not sure the brand name, but it is good quality US fluid. Both of them are gone now.
brand names dont say anything about quality. The international codes, API, SAE, MIL are quality levels.
I use DOT4 without any problems so far.
Sometimes, when DOT4 is mixed with DOT3, chemical reactions occur that eat your rubber parts....
I use Silicone Brake fluid as it doesn't absorb water.Also I have found that just putting the cap off an aerosol can over the brake fluid cap keeps rain water out of the brake fluid and stops the cylinders corroding.
Hi all. i am currently looking for a workshop manual for a 3545... does anyone know where i can get one from??
