question Zetor 3320 oil cleaner canister leaks
D
delmer
Guest
started by Zetor 3320 today and oil was leaking out of the 2 oil cleaner canister these have washable screens in them. are there o rings
in these that might be bad and cause the leaking? i have tightened the nuts on top but still have leaks.
thanks in advance for any help . delmer
There is a seal at top of the bowl (part number 931102) that needs replacing. If the oil is leaking from the bottom of the bowl you will have to replace the bowl (part number 931103)
