Hello.
My hi/low shift seems to be broke it just moves back and forth freely. I took the boot off and it looks like it goes in side of transmission. It moves freely on the outside, would this be an easy fix or hard. Thanks for your help .
That is not a easy fix. as you need to open of the transmission up and have a look. I wood say to have a good study of the parts manual first before you start with the job.
Remove middle floor panel,
to do this the lower panel of the steering column must also be removed
Remove left floor panel as well (5 screws)
Remove gearshift dome (4 screws)'
Remove manual transmission cover - remove all screws
and then lift the cover slightly at the front and first pull slightly to the left side and then lift it out
Installation in reverse order.
You may need a new manual transmission cover gasket or fluid seal and two new gearshift dome gaskets as well as some Loctite (medium strength screws) and possibly a few new spring washers.
In addition, other spare parts may be required depending on the situation.
