question ZETOR 3340 HYDRAULIC MYSTERY
ModernSerf
Virginia
Andrew
Zetor 3340
My Zetor 3340 developed leaking cylinders on the loader, was using it for some work while keeping the fluid topped off and noticed that lifting ability of the front end loader was starting to diminish slowly.
First, it could not keep a bale of hay elevated, and then, while digging a small hole, it completely quit functioning.
It never bled dry, always filled it up and used it extremely sparingly, but when it quit, we removed the cylinders and had them rebuilt by a local shop.
I reinstalled the cylinders, topped up the reservoir and fired the tractor up. The three-point hitch responded by raising up once.
However, it could not seem to build any pressure in the front end loader.
You could tilt the bucket and lift it maybe an inch or two. I tried several times for a couple hours trying to bleed the system by articulating the front end loader with the reservoir cap open making sure it was topped up with fluid.
Eventually, I realized that no pressure was building. I opened the test port on the valve block of the loader and heard a poof of pressurized air and took a look inside and it was mostly empty. When I relieve pressure from the loader block using the hydraulic controls, I can hear swishing gurgling fluid as the pressure releases.
I was thinking maybe the loader blocks relief valve was messed up, but I spoke to Petor from Zetor North America and he told me to try priming the pump by cracking a line on the outlet of the pump.
I did that and only got a small stream of fluid coming out. From what I understand it should be spraying everywhere at 2000 psi?
I also tried bleeding the farthest cylinder on the loader and similar trickle stream of hydraulic fluid but no spraying.
I spoke to Petor again and he suggested to me that the most likely culprit was that the pump went out.
I just wanted to doublecheck on the forum to see if anybody else had any suggestions of what the troubleshoot before I ordered the expensive pump and went through the process of installing it.
TLDR: NO HYDRAULIC PRESSURE on 3 PT or FRONT END, HOW DO I KNOW THE PUMP IS SUSPECT?
To test, plug a hydraulic pressure gauge into one of the external connections at the back. If it can't build up pressure there (160-170 bar / 2,300-2,450 psi), then something's wrong.
The following could be defective:
- Hydraulic pump
- Main pressure relief valve
- Depending on how your external front loader control block is connected, the internal control block could also be defective.
But I would also consider the pump a likely problem if, as you describe, it has suffered from oil starvation several times. It's never good for the pump if it's running dry or sucking in air.
- Hydraulic pump
Thanks for the reply. Would you happen to know where is a good test port to measure the pumps pressure? Idea on thread pitch?
Extertal hydraulic connectors at the back side of tractor where you can connect hydraulics for Tools in the 3-point hitch eg.
Or betwen hydraulic pump ans pipe to external hydraulics valve block.
Extertal hydraulic connectors at the back side of tractor where you can Connecticut hydraulics for Tools in the 3-point hitch eg.
Thanks for your answer. I’m determining that my model has the hydraulic pump in the rear axle? I’m still not entirely sure, but I don’t see any other external hydraulic pump and I’ve got several hoses that lead from the loader blocks to the three-point hitch.
My question is where do I refill the transmission/hydraulic pump with new fluid?
There seems to be a bolt underneath the seat, behind a rubber flap that I’ve labeled in the picture here? Is that it? Also, based on the pictures, can someone confirm that my pump is in the rear axle? Where is the dipstick?
To check the Transmission/Hydraulic oil is by the gear shift lever.
Looks like I may have the same model hydraulic valve that you have.
The hydraulic pump that powers my Quicke 720 loader is located on the left side of the diesel engine.
The pump that you are showing by the engine fan may be for the power steering.
