question Zetor 3340 not shutting down
freebird01752
Kentucky
Steve
Zetor 3340
Hi guys my 3340 will not shut down using the throttle handle. I can hear it click when fully pulled down. What is the leaver connected to so it shuts down?
Thanks for any info for this problem
Steve
I believe the throttle lever connects to a cable and goes to the injector pump.
Check the linkage at the throttle lever first.
Then if the trouble is not there, check the linkage at the injector pump on the left side of the Zetor 3340.
- check the spring number 128 to
- adjust on number 109 at both, its 2x mounted
Hey guys, thanks for the info. The throttle lever will operate the fuel like it should. But when I pull the lever all the way to the stop position it stays running. The only way to shut it down is by stalling it out using the clutch. Which puts a lot of strain on the clutch.
In the sketch that Joachim posted, it shows the rod assembly linkage is adjustable.
Did you try adjusting it so that the throttle injector lever is fully closed when you move the hand throttle to the fuel OFF position?
I am thinking if the throttle linkage becomes worn out it may have lost its ability to close off the fuel completely.
I haven't adjusted it as it has been raining here and I haven't gotten a chance. I hope to work on it Monday.
I'll let you guys know either way.
Thanks again for the advice
