- Feb 13, 2024
- 167
- Location
- Windsor Vermont
- Robert
- Machinery:
- Zetor 3340 with Cab and Loader 1995
Zetor 3340 Changing the Power Steering Fluid and Filter June 2024
When checking the Power Steering Fluid, it was white in color and so this is an indication of water in the fluid.
Note, there is a lot of water, where as some of it can be seen separated from the white milky fluid.
So the question is, how did the water get into the Power-Steering-Fluid ?
I believe, because the Power-Steering-Fluid-Reservoir is not covered from the open air and there is a Vent-Hole manufactured in the Cover-Retaining-Bolt,
water from rain and washing has entered and contaminated the Power-Steering-Fluid over the past 25 + years.
My fix for this water-contamination has been to place a plastic container over the top of Reservoir so that it will prevent this trouble.
Servicing items Used:
Power Steering Fluid: Traveller Premium Anti-Wear Hydraulic Fluid ISO 32, Uses: 1.5 Gallons (4.8 Liters)
Power Steering Filter: 93 1154
1st Unscrew the power steering fluid reservoir retaining bolt and remove the spring and the spring retaining washer.
Next pull out the filter to place it may drain the fluid out of it.
2nd Down on the left side of the Zetor, where the power steering cylinder is located and to where the left side pressure-line is attaches,
I placed a pan under the axle to catch the fluid and removed the left side pressure-line so that it would drain.
This did not drain all the contaminated fluid out, as could not see where or how to do a complete fluid drain easily.
Next, I cleaned all the contaminated fluid out of the power steering fluid reservoir and using an airgun blow out all that was able.
You will see in the pictures some of the water that was not able to mix in with the Power Steering Fluid.
3rd I reassembled the fluid pressure-line and installed the new power steering filter.
Then filled the reservoir with the new fluid and installed the spring retaining washer, spring and cover with the vented-bolt.
4th Next, I started the engine and turned the steering wheel from one side to the other several times and then shut the engine off.
Then I opened the top of the Power Steering Reservoir and saw that I still have the white milky fluid.
I repeated this flushing process two more times, which did help in reducing the water amount that is mixed in the power steering fluid.
5th I may revisit this trouble later hoping to be able to flush all the contaminating water out of the power steering fluid system.
I also saw what looked to be a weeping leak at the left side pressure-line, which has copper washers on each side of it used as seals.
Examining the copper washers, one of them had some damage, which I was able to sand down by hand to correct this imperfection.
All the metal surfaces also had some rusting on them, which I was able to clean up with a small stone.
This seems to have fixed this small trouble, but I will keep and eye on it for a time to make sure.
The working of the Power Steering has no symptoms of any troubles before and after.
Though, the old filter was bulge out where the out side metal support seam came together.
This caused me to look at why is it bulged out, (?) which I am not sure what has caused this.
The direction (path) of the flow of the fluid is taken from the inside of the filter (center) and is returned to the outside of filter,
which if the filter had collected a lot of debris would have pushed in on the outside of filter (not filter being pushed out).
Maybe, with so much water in the Power Steering Fluid and the paper filter may have soaked up with water
so that when it froze, the outside metal seam being the weakest point, had bulged out (maybe).
The old filter did not look bad (used up) and the fluid did seem to be easily passing through it.
