question Zetor 3340 - What kind Hydraulic/Transmission oil and filtre do I need ?
Hi Joachim,
I received the order and there are several errors in it,
but before I call Rene J Fournier's Farm Equipment
I have the part numbers for the other two filters
and can you verify that they are correct part numbers for my Zetor 3340 ?
Fuel Filter Element 4-3/8” Long: 93 1273
(Power Steering) Filter for Metal Steering Tank 5.5” Diameter: 93 1154
With my order through a dealer in northern VT,
one of us may have missed spoke with one of the part numbers
as they do part-orders by land-line phone
(they do not have email, cell-phone and a web order parts page).
So I am not able to see what each part cost with tax and shipping.
Anyways, the error is with the Small Rubber Seal: 931136
and in the place of was ordered 931130 (screw) Long-Bolt for the filter assembly.
This bolt will be mailed back and the Small Rubber Seal: 931136 will be shipped to me soon.
Iam in holidays, so I can take a look after that.
I am having trouble identifying what kind of Zetor 3340 Power-Steering Fluid (oil) that I need to change it with.
The chart indicates to use: OH-HM-42 Fluid, but when I do a search it, I get a list of all kinds of fluids.
What should I be looking for ?
Best will be a HLP 32 oil or if not possible to buy it, then a HLP 46 oil.
But never ever a SAE 80W90 or similar ;)
So then, this will be good ?: https://www.tractorsupply.com/tsc/p...pf0QCcQMV9CvuwafB32fPaRJ7aefsj0kaAqsWEALw_wcB
Traveller 5 gal. Premium Anti-Wear Hydraulic Oil, ISO 46​
or would this be better ?: https://www.tractorsupply.com/tsc/p...IR_kz0bAeYmFEjRop4jws6L1AqL_89EaCU7GHvZZHMvt4
Traveller 2 gal. Premium Tractor Trans/Hydraulic Fluid​
  • Premium hydraulic fluid helps reduce wear and brake chatter and helps extend equipment life
  • Formulated to provide superior protection for modern farm equipment
  • Special multigrade (SAE 10W-30) fluid blended with the highest quality lubricating oils and the most technologically advanced additive system
  • Employs a common sump to lubricate hydrostatic transmissions, differentials, wet brakes, hydraulics and final drives gears
  • Designed for low temperature pumpability, excellent thermal stability and gear protection
  • Universal hydraulic fluid recommended for 100+ OEM applications (see label for complete list)
  • Meets J20C requirements
  • Includes 2 gal. bottle of tractor hydraulic fluid
I think better this one:
Its a ISO 32, so I think its similar the the european HLP 32.
OK, Thank you, I will get this then for the Zetor 3340 Power-Steering,
Traveller Premium Anti-Wear Hydraulic Fluid ISO 32 protects against rust, corrosion, foaming and oxidation.
A multi-grade blend, this motor oil features the highest quality lubricating oils and the most technologically advanced additive system.
Use the hydraulic fluid with any compatible industrial or mobile hydraulic system.
  • Protects against rust, corrosion, foaming and oxidation
  • Anti-wear additives in the motor oil protect critical system components
  • Premium multi-grade blend featuring the highest quality lubricating oils and the most technologically advanced additive system
  • High-quality oil formulated for industrial and mobile hydraulic systems, including: Sperry Vickers M-2950-S and I-286-S, Denison HF-0, HF-1 and HF-2, Cincinnati Milacron P-68, P-69 and P-70, DIN 51524-3 and ISO 11158 HM
  • Non-chlorinated
  • Meets ISO 32 (SAE 15W Equivalent) requirements
  • Includes a 2 gal. bottle of hydraulic fluid
  • Made in USA
  • Note: This product is not recommended for transmissions, differentials, wet brakes or final drive gears; use Traveller Premium Universal Tractor Fluid for such applications.
Exactly
HLP 32 = HVLP 32 = ISO 32
But it works also very well in middle european climates - I use it since years and we have summers with up to 40°C in Middle Germany. No problem. We also have days at winter with down to -20°C and there will be HLP 32 the best choice to.
Temps where I am in New England VT USA, can have a few days as high as 36°C (98°F) summer and as low as -40°C (-40°F) winter.
But, because the world is in its 100 year cycle of warming temps and so the winters are running warmer now.
Back in the 1960's it was normal then and will again in the 2060's, will be back to its normal colder winter temps again.
Then HVLP 32 will be the best choice. :)
Next I would like to change the Portal Rear wheels oil.
The info fluid chart says, PP 80 for oil, which I am not sure what this is.
The fluid chart also says each side takes about 2 Liters, so for both sides would be a little over 1 gal.
Paramol PP 80 oil = SAE 80W-90 API GL4 UTTO oil ;)
And yes, 1,5-2 litres for each side (up to the oil level control screw)
Sorry for being late. Haven't been online much recently. Might be incorrect, but I have used universal tractor transmission fluid in my tractors for years with no apparent ill effect. (On the trans, of course). Your local Napa dealer can get filters for you. My local Napa usually has them on the shelf. I do order frequently from ridgeway. Also one in Canada called Tractor parts direct.
I did go to my local NAPA and they were not able to find any filters for Zetor . Maybe not all Napa's are the same.
I may be the only Zetor owner that is local. Thank you for your very good reply it is a help .
You are not alone... ;)
Yes, I have looked at this several times and like seeing where there are other people using Zetor tractors.
I have all the oil and filter that I need now.
And so, I am hoping to do a post about each oil, filter change, when I have the time to do it with.
I am enjoying the learning and the servesting, as well as the fixing things on my Zetor 3340.
Here is my list of oils and filters that I have for servicing Zetor 3340.
Diesel Motor Oil: Shell Rotella T4 15W-40 Diesel Motor Oil,
Uses: 2.5 Gallons (9 Liters) Tractor Supply: 5gals cost: $65.00
Filter: Wix: 51243 or SANEL/NAPA: 1243 cost: $15.69
Fuel Filter: 93 1260 cost: $28.58 (+ shipping and tax)
Power Steering Oil: Traveller Premium Anti-Wear Hydraulic Fluid ISO 32
Uses: 1.5 Gallons (4.8 Liters) (cost: $19.99 for 2gals)
Filter: 93 1154 (cost: 42.47) (+ shipping and tax)
Gearbox/Hydraulic Oil: Ultra1Plus SAE 75W-90 Synthetic Gear Oil, API GL-4
Uses: 9 gallons+ (34 Liters) (cost: $485.60 20gals) Ultra1Plus SAE 75W-90 Synthetic Gear Oil, API GL-4 (5 Gallon Pail) | eBay - https://www.ebay.com/itm/333676978297
Gearbox/Hydraulic Filter: 7011 4566 (cost: $35.71)
Big Rubber Seal: 7011 4563 (cost: $11.47)
Small Rubber Seal: 93 1136 (cost: $01.00) (+ shipping and tax: $39.66)
Front Axle Differential Housing (Cas Carraro Axle): 85W90 GL4 Gear Oil - Liqui Moly 20016
Uses: 1.5 gallons (5.5 Liters) (cost: $75.39 for 8 Liters)
Carraro Front-Wheel Planetary Reduction Housing Oil: Ultra1Plus SAE 75W-90 Synthetic Gear Oil, API GL-4
Both Wheels Uses: 1.3 qts (1.2 L)
(Cost: $485.60 for 20gals) Ultra1Plus SAE 75W-90 Synthetic Gear Oil, API GL-4 (5 Gallon Pail) | eBay - https://www.ebay.com/itm/333676978297
(may also use: SAE 80W-90 API GL4 UTTO)
Portals Rear Wheel Oil: Ultra1Plus SAE 75W-90 Synthetic Gear Oil, API GL-4
Each Wheel Uses: 2qts (1.9 L) Both together 1gal
I have move it to our FAQ section and edited a litle bit for better reading and for additions...
And I wonder, why the prices for Zetor parts are so much high at your country. :oops:
I believe the short answer is:
The USA is being torn apart by bad people who hate Jesus Christ and His precepts.
The good USA people have lost control of the country.
Inflation is being caused by these bad people on purpose.
So what is reported to being the cause of a trouble is not the true truth.
These bad people work for the one who is a thief, a liar and a murderer.
So watch the world events as they are changing to match what Jesus said will be happening and is happening.
I need to stop here as this is a forum for Zetor tractors.
