question Zetor 3340 wiring diagram
For 3340 there exists only the b/w one from the manual .
Colored ones it gives only up to Zetor 5211 to 7745 Turbo.
What part is not to read for you? Maybe I can help .
Thanks for replying
All the numbers for the pins on the 3 Booster relays are unreadable so cannot tell which wires goes to which pins. Would a diagram for a 5245 be the same? I believe my 3340 was the first into the UK in 1993 and was basically a 5245 with different colours!
Ok, yes these 3 works like at a Zetor 5211 to 7745 Turbo for heating fans.
Do you have a wiring diagram for 5211 to 7745 Turbo?
Take a look at our new section in our FAQ :
Hello Again,
I have tested the 3 booster relays in cab roof and all OK. I have also traced all the wiring in cab roof as per the wiring diagrams supplied and it seems OK. The problem I am having is that Fuse No. 10 in attached diagram keeps blowing when fans are switched on. When the fans or the ignition are not on I am getting 12V across the two terminals at fuse 10.
Tried disconnecting all relays but still get 12V across No.10 fuse pins. Don't know where the power is feeding from!
