zetor 3511 hydraulic pump
darshanpatil
Darshan Patil
can we fit hydraulic pump on engine of zetor 3511 instead of gear,like ferguson or international.Because i guess these tractors get high lift pressure than our tractor.we require much raise of throtle to get high pressure.
your pump is worn. replace it, dont bother about a crankshaft driven pump unless you need to use hydraulic power with the PTO shut down. these pumps can deliver 160 bar max, 150 at 1000 engine rpm.
