Zetor 5011 Value
jgmac
JGMAC
Hi, I was wondering if anyone could maybe give me a rough idea of what a Zetor 5011 1983 model would be worth?
It has only done 855 Hours in its life and is in very good condition, it does however require the rear brakes to be looked at, was told it was the rear brake cylinders that needed replaced.
I have no real idea of what its worth so would really appreciate any advise.
Cheers.
i have no idea what the value of your prospective tractor may be, but just a heads up, if 5011 brakes are similar to my 6711 brakes 'just' changing the wheel cylinders is quite a major operation for a novice (like me).
you have to remove the rear wheels and axle housings, which obviously means big spanners and big jacks.
I would be interested in your tractor - whereabouts are you would you be able to send a couple of pictures?
jason.kitching@btopenworld.com / 07710 161670
Regards Jason
