question Zetor 5748 hydraulic oil filler point
paul1763
paul1763
Hi all, on the 5748 is the hydraulics run from gearbox or is it filled
through magnetic filterplace under rear of seat?if the latter, which oil is best to use and how do I check the level? Thanks for any answers.
From the gearbox trough filterplace.
Oil: SAE 80W-90 API GL4
Level check: just unsrew above your gearbox the control screw and check the level.
