Zetor 6245
seedspreader
seedspreader
Thinking of purchasing a 6245.
It has a LEON 6911 loader on it. It has 2134 hours on it.
It's a 1986.
I'd appreciate any insight that you might be able to offer. Anything I should look for?
I've read mixed reviews on the tractor. Obviously I'm coming to this forum because I want the good, the bad and the ugly.
Thanks in advance!
clutch and brake master cylinders: They are about 70 euro and if the original ones from PAL are still fitted, they need replacement at around 3000hrs usually. They had a cylinder coating that let loose so dont put in a new set of seals, because the liner will make it leak again. The newer ones are of Fragokov brand.
They sometimes double shift but your dealer can install a modification kit (or you can do it yourself if youre handy)
The good: the front axle is comparable to the one on a wheeled loader. very strong. (that is, if it has the heavy planetary axle, in some countries they sold the light duty 5245 front axle with pinion/ring gear reduction on the 6245 too but its not that heavy.
Water pumps sometimes fail but i buy them for 25 euro ex post.
The tractor itself is heavy duty, and the parts that sometimes fail are cheap in the aftermarket.
I do need two new master brake cylinders but here in NZ they more often than not ask pharmacy prices. Where do you get them from?
www.ibeno.cz
Lukas speaks good English and is correct in his business.
Thanks Renze,
I'm trying to post a picture of the one I'm looking at but seem to get a "conflict" error.
Pictures here:
http://themodernhomestead.com/Blog/?p=925
Try again to post one here...
can't get it to work...
apart from the very stupd looking loader taking all th visibility away forward. the tractor is a very good buy. dont see them around here as an open station.
