zetor 6245
doorknob
paul s
Hello, I have zetor tractor 6245 and would like some information on how to activate the power take-off from 540 to 1000 rpm thank-you paul
Does yours have a twist lever centered right in front of the seat ? you should be able to rotate it 180 degrees from left to right. If its stuck from not being used, tap it free while spraying WD40 or MoS2
If your tractor has shuttle reverse: then it doesnt have 1000rpm PTO.
