question Zetor 6320 stops when gas tank half full
photosbymorgan2
Paul Morgan
Have a 6320 Zetor that will stop running once the gas tank is half full. Have not found any air leakage issues.
Any ideas what I should look for?
Paul
When it stops, does the filler cap come off, or is it vacuumed? If the breather is plugged it wont feedto the pump.
it may also have a crack in the suction pipe inside the tank. try to run it from a 10 liter can of fuel . but put both return and suction hose in the 10 liter can. if it runs then the fault is in the tank.
